IM & P Federation when you have multuiple presence domains
Carwyn Jones
I'm looking into enabling  Federation either SIP or XMPP from IM & P 10.5 to external oganisations.
i have 5 system managed  domains within a single CUPS Cluster,  I am trying to determine if its best to setup federation via expressway or IM & P.
Expressway does not support Email address translation but i am unsure if i would require this feature considering i have 5 presence domains.
would i require email address translation, given the number of presence domains i have? otherwise how does Collab edge allow for this in a federation deployment?
Jaime Valencia
It will simply use whatever you defined as JID, the recommended way right now is to use EXP-E
The same JID format will be used for any number of domains you're handling, not sure what you're asking here.
java
if this helps, please rate
thanks Jamie you answered my question.
