09-13-2012 07:22 AM - edited 03-19-2019 05:31 AM
Hey guys, got a question that has been irritating me to no end for the last couple of days. I am setting up a 2921 and have an SRE module that I want to install CUE on but I can't seem to get the FTP to work correctly. I load the package, get the language selection and wait for the module to reset and then I get the error that has been my bain for a couple of days now. Any insight on what I am doing wrong would be greatly appreciated. Below is the error as well as my configuration.
Router#$install url ftp://user:123456@10.0.0.2/cue-vm-k9.sme.8.0.5.pkg
Proceed with installation? [no]: y
Loading cue-vm-k9.sme.8.0.5.pkg.install.sre !
[OK - 22272/4096 bytes]
Following languages are available for installation.
# SKU Language Code Language Name
1 ITA it_IT CUE Voicemail Italian
2 ESP es_ES CUE Voicemail European Spanish
3 ENU en_US CUE Voicemail US English
4 FRA fr_FR CUE Voicemail European French
5 ESO es_CO CUE Voicemail Latin American Spanish
6 ESM es_MX CUE Voicemail Mexican Spanish
7 ARA ar_SA CUE Voicemail Arabic
8 NLD nl_NL CUE Voicemail Dutch
9 SVE sv_SE CUE Voicemail Swedish
10 NOR no_NO CUE Voicemail Norwegian
11 FRC fr_CA CUE Voicemail Canadian French
12 PTG pt_PT CUE Voicemail Portuguese
13 TUR tr_TR CUE Voicemail Turkish
14 HUN hu_HU CUE Voicemail Hungarian
15 ENG en_GB CUE Voicemail UK English
16 DEU de_DE CUE Voicemail German
17 DAN da_DK CUE Voicemail Danish
18 PTB pt_BR CUE Voicemail Brazilian Portuguese
19 KOR ko_KR CUE Voicemail Korean
20 CHS zh_CN CUE Voicemail Mandarin Chinese
21 JPN ja_JP CUE Voicemail Japanese
22 RUS ru_RU CUE Voicemail Russian
You can install upto 5 language(s) on this platform.
Please select the language(s) you want to install by entering the language number(s)
Languages can be entered as comma separated or space separated list
Example: 1,3 would select 'Italian' and 'US English'
Enter languages:3
Following languages will be installed on the system:
Do you want to continue with the selected options?(y/n):y
input string: lang=no=1,CUE Voicemail US English
Router#
*Sep 13 14:13:26.847: %SM_INSTALL-6-INST_RESET: SM1/0 is reset for software installation.
*Sep 13 14:15:09.491: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Registration Request
*Sep 13 14:15:09.495: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP File Request
Error message(code:0) Bootloader tftp error received on SM1/0
*Sep 13 14:16:10.711: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Error Msg Req
*Sep 13 14:16:10.711: %SM_INSTALL-6-RBIP_ERROR: Error message(code:0) Bootloader tftp error received on SM1/0
Abort successful on SM1/0.
*Sep 13 14:18:14.479: %SM_INSTALL-6-INST_RBIP: SM1/0 received msg: RBIP Registration Request
*Sep 13 14:18:14.479: %SM_INSTALL-6-INST_ABORT: SM1/0 SW installation aborted, reason:Bootloader tftp error
Configuration:
Current configuration : 1786 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip cef
voice-card 0
license udi pid CISCO2921/K9 sn FTX1538AKLC
hw-module pvdm 0/0
hw-module sm 1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
hold-queue 60 out
interface SM1/0
ip unnumbered GigabitEthernet0/2
service-module fail-open
service-module ip address 10.0.0.3 255.255.255.0
service-module ip default-gateway 10.0.0.1
hold-queue 60 out
interface SM1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.0.0.1 255.255.255.255 SM1/0
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end Current configuration : 1786 bytes
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip cef
voice-card 0
hw-module pvdm 0/0
hw-module sm 1
redundancy
no ip address
shutdown
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
duplex auto
speed auto
hold-queue 60 out
interface SM1/0
hold-queue 60 out
interface SM1/1
no ip address
interface Vlan1
no ip address
no ip http server
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
end
Any insight on what I have messed up? This is the first time I have had to set up a CUE and used Cisco's document for help here: http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/ism-sm-sre.html#wp1140891
This was helpful but doesn't correct my problem and need some additional assistance as you can see. Thanks for everything!
10-01-2017 10:44 PM
I was having the same issues. Connectivity was OK, configs were OK. After many attempts, I decided to remove the module's hard disks and format them with Rufus. I got my module on ebay for studying, but we never know what is inside the hard drive. After formatting both drives and using the commands to reinstall CUE in the module, I was successful.
If you format the disk, when you put it back in the module, the installation program will reformat in the correct file format for the system. We never run into this issue when we go to customers because we either get the module with no data in the disks or pre-installed with the software we're going to install for our customers. But creating your own lab at home always gives you unexpected challenges...
I hope this reply helps somebody else in need.
Cheers!
