Installing Unity Connection 7.1(3) on HP DL380 G6
nelson.chu
Has anyone installed Unity Connection 7.1(3) on HP DL380 G6 servers?  I am having problems installing the Disk Array driver.
Nelson
Tommer Catlin
How many drives do you have in the server?  If you have more than 2, pull out the rest and see if install through
I have DL380 G7 servers with (4) 300 Gig Hard drives.  When I try to install the UC 7.1(3), it is prompting me to install the correct array controller dirvers.  I have found the drivers from HP site, but it requires going into Linux.  Has anyone else had this issue or workaround?
You may need to find a Unity Connection 7.1.5 boot disc and try that way.   Or is there a need for CUC 7.1?  Go up to 8.5 if you can (SU1)
