Integrating cucm with 3rd party using API
tarek.issa1
hope all is well!
Please i want support in integrating a third party platform with CUCM version 12, where i retrieve all info regarding users and their extensions to it so i can search for anyone easily.
I am currently exporting phones from bulk administration and then import them to the 3rd party platform every time we modify, delete or add a user.
I couldn't link this platform to my Active directory since i have more than 1000 users without their directory numbers added on the server , so i want to link the CUCM with my 3rd party platform directly using API
The available way to interact with CUCM is using the AXL API if your third-party system supports it. I would recommend using provisioning tools like Kurmi, which can communicate with CUCM and be used for adding and deleting phones, as well as handling all provisioning tasks. There are other tools available as well, which you can search for or someone from this community might recommend.
For more details on the API, you can check the links below.
  1. https://developer.cisco.com/docs/axl/axl-developer-guide/
  2. https://developer.cisco.com/docs/axl/what-is-axl/#what-is-administrative-xml
Response Signature
tarek.issa1
Dear @Nithin Eluvathingal ,
Thank you for your reply.
Just want to ask you if there is any official and clear guide that helps me integrating my 3rd party platform using API since this is my first time?
That is the official page for all API-related documentation, and you can find everything related to CUCM there. If you are a beginner in this area, you might need expert support or engage your developer for third-party applications.
Response Signature
