Interface Shutdown
Brian Hebertson
Level 4
Level 4
I am turning up an E1 in Australia. The circuit is currently connect to an Avaya g430 T1/E1 card and working. The provider is use a One700 SHDSL to ISDH converter by One Access. When it connect to One Access One700 PRI port the interface stops responding and throws an alarm.. My Interface on my NIM-2MFT-T1/E1 shows down. The logs show it up for about 15 seconds then down. I would like to know if there are any records of connecting to this type of device and what configuration I might be missing. Below are some of the details.
card type e1 0 1
voice-card 0/1
no watchdog
voice-card 0/3
no watchdog
controller E1 0/1/0
framing no-crc4
clock source line primary
pri-group timeslots 1-31
controller E1 0/1/1
framing no-crc4
clock source line secondary
interface Serial0/1/0:15
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
trunk-group PSTN
interface Serial0/1/1:15
encapsulation hdlc
trunk-group PSTN
voice-port 0/1/0:15
voice-port 0/1/1:15
network-clock revertive
network-clock synchronization automatic
network-clock input-source 1 controller E1 0/1/0
network-clock input-source 2 controller E1 0/1/1
what kind of alarm?
Use the following command to check the controller:
show controller e1
Best regards,
Marcelo Morais
Jonathan Els
Level 5
Level 5
Need the following:
show controller e1
debug isdn q921
Questions generally to ask:
  • ISDN switch-type?  I assume you're primary-net5
  • Who's doing clocking?  99.999% provider, but I've had funnies before.
  • Framing - cyclical redundancy?
For all of these types of issues, this is the holy grail:
E1 Troubleshooting - Cisco
E1 Alarm Troubleshooting Flowchart - Cisco
E1 PRI Troubleshooting - Cisco
