Intermittent Unity/Web/SA login problem after upgrade to Windows 2003 SP1
asimkamran
Hi there,
We perform Exchange 2003 upgrade to SP2 and Windows 2003 to SP1 and now we are having intermittent login problem when we try to access the System Admin page. There is no error message in the Event Viewer.
We are running Unity 4.0(4).
I have already confirmed the privileges on AvCSGateway and AvLic on DCOM and for local activation all the access is provided to the users. Any help will be appreciated.
Asim
tjjorgensen
Level 4
Level 4
I have a client running the same versions on a Exchange cluster and have the same problem, the Unity servers are 4.2(1) on win2k3sp1.
I worked three different tac cases but was never able to isolate the issue. All cases are now closed. With micro and macro tracing as well as IIS debugging running, we never collected any good data on why this was happening.
We expereince this problem roughly two or three times a week, and if left unattended it will correct itself gracefully within roughly two hours.
I wrote a SAfix.bat for the client to just restart the services in a certain order because if I tried to shortcut this process and just restart wwwpub, services would get stuck in "stopping" until the server was restarted.
This will knock off PCA users for a short time so I try not to use it during business hours:
net stop netlogon
net stop w3svc
net stop smtpsvc
net stop nntpsvc
net stop httpfilter
net stop iisadmin
net start iisadmin
net start httpfilter
net start nntpsvc
net start smtpsvc
net start w3svc
net start netlogon
IF you find the root cause, PLEASE post it back here!
We've had the same issue; what's worked for us is to go into IIS Manager, right-click on the Application Pools and modify the Default Application Pool properties -> Health. We changed the ping time to 10 seconds, and _disabled_ "Enable rapid-fail protection".
Seems to have worked, but don't know why.
