11-24-2004 05:58 AM - edited 03-18-2019 03:53 PM
Using the above in version 2.0.0.20, fax dnis=645xxxx and the service is configured to route according to the 4 right digit and to match extension ID.
The problem is that it always fail and use the entire dnis, only when i define the 7 digit in the subscribers extension field, it routes correctlly.
Any ideas ?
Avner.
Solved! Go to Solution.
11-24-2004 11:04 AM
Version 2.0.22 has been posted:
http://www.ciscounitytools.com/App_IPFaxConfigurationWizard.htm
this version also includes support for CSID information optionally being included at the top of the fax pages going out.
11-24-2004 09:31 AM
Avner,
You've done everything right, but have run into a defect in the IP fax service. It's fixed in version 2.0.0.22, which should be posted to CiscoUnityTools.com later today.
-Ken
11-24-2004 11:04 AM
