IP Trade Systems Documentations
CSCO12047864
Hi to all,
I need some documents about CUCM configuration to work with IP Trade Systems.
I have something from BT, but i didn't find anything from Cisco.
Anyone can suggest me where i can find it?
Ashish Patel
If you need more reach out to IP Trade/BT directly which I think you have because as you may not know already May 2017 "BT today announced it has completed the acquisition of IP Trade"
What have you looked at so far? Have you see the link below which has documents at the bottom of this page which speak to the solution and some are already BT branded.
https://developer.cisco.com/ecosystem/spp/solutions/90122/
ashish
Response Signature
Ashish Patel
ashish
Response Signature
Thank you for your answer Ashish Patel,
I already checked the link you send me and the datasheet of the products.
I'm searching some technical documents, like how to configure user, SIP profile, device and so on.
I found these documentations only on BT web site.
Does Cisco have its own documentation? Or Cisco totally delegate technical documents to BT?
