07-29-2009 11:12 AM - last edited on 03-25-2019 09:31 PM by ciscomoderator
Hello Everyone:
I am trying to integrate a cucm ver 6.1 with a Avaya g3 ver 13 through h323 ip trunk.
I am using this document to make this possible, but the Cisco Ip phones can't call the avaya phones, neither the avaya phones can't call the cisco ip phones
http://www.avaya.com/master-usa/en-us/resource/assets/applicationnotes/h323-trk-cm-ccm.pdf
http://www.avaya.com/usa/resource/assets/applicationnotes/ip-trunk-cm.pdf
I want to know if somebody has done this kind of integration, could you provide me with the docs?
Rdgs
07-29-2009 12:51 PM
please refer to this document:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/pbx/interop/notes/430317av.pdf
Even though the software version on CUCM is older, and the note was written for the newer Avaya S8500 platform, the application note is still applicable.
Tony Arcoraci
UC Interoperability Group.
07-29-2009 01:09 PM
Thanks.
I going to try the integration with the doc.
I will post the results asap.
Rgds
08-07-2009 10:31 AM
08-07-2009 10:45 AM
I can't decipher that trace, and therefore cannot see what's going on with your failed outbound calls from CUCM to the Avaya PBX. I suggest you contact our TAC group, if you haven't done so already, so that someone may look at the trace and be able to tell you what do change in order to get your system working fine.
Tony
10-27-2009 11:39 AM
When I set this up in our Lab I had to set check "Enable Outbound FastStart" on the Device > Gateway > Call Routing Information - Outbound Calls
Not sure if thats the issue but worth checking.
If you do a list trace tac (trunk access code for the H.323 trunk) and paste the results in here I miht be able to help more.
Regards Greg
