IPMA and +E.164 dialing possible?
m.ranger
Is it possible to to dial +E.164 numbers with the IPMA assistant console?
I have a +E.164 enabled CUCM 10.5 and can dial +E.164 numbers with all devices and applications, but not with IPMA assistant console. IPMA Assistant Console version is 6.5
Best regards
Manfred
Manish Gogna
Hi Manfred,
This feature was introduced in CUCM 7.x so it should work
Manish
- Do rate helpful posts -
5 Replies 5
Manish Gogna
Hi Manfred,
Manish
Hi Manish,
I don´t have access to this bugID. Can you please send me some informations.
Best regards
Manfred
Hi Manfred,
I removed that link as there was some issue with the same. You can check the following documentation for IPMA
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/3_3_2/ccmfeat/ccmfeat/fsipma.html?referring_site=RE&pos=1&page=http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/41984-ipma-routing.html#wp1072423
Dial Rules Configuration Error Checking
The Cisco IPMA dial rules perform the following error checking in the Dial Rule Creation section of the Dial Rules Configuration window:
The phone number begins with field supports only digits and the characters +*#. The length cannot exceed 100 characters.
The number of digits is field supports only digits, and the value in this field cannot be less than the length of the pattern that is specified in the pattern field.
The remove digits field supports only digits, and the value in this field cannot be more than the value in the number of digits is field.
The prefix it with field supports only digits and the characters +*#. The length cannot exceed 100 characters.
Ensure that dial rules are unique.
The remove digits field and the prefix it with field cannot both be blank for a dial rule.
Manish
m.ranger
IPMA is working now with +E.164 numbers.
The problem was that during migration from CUCM 8.6 to 10.5 a new application dial rule was created automatically which has stripped every leading "+" sign. After deleting this application dial rule everything was ok.
Thank you Manish for your assistance
Best regards
Manfred
Thanks for updating the post Manfred.
