10-22-2010 12:01 AM - edited 03-19-2019 01:47 AM
Is it possible to answer calls from another extension with CCM?
for an example, if i transfered a call to a wrong extension will i be able to get that call back to my extension if it is not answered by the other person?
10-22-2010 11:02 AM
You could use call pickup groups, http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fscpickg.html. However if the transfer finished (press transfer dial the number, press transfer again) the destination would have to be a part of your pickup group or use the other pickup group option.
10-22-2010 11:48 AM
I believe that what you're asking for is transfer reversion, however CUCM does not implement this capability.
The only possible method is what Joe mentioned about call pickup groups.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-22-2010 08:04 PM
Yes. It is similar to transfer reversion. If operator puts a call to a wrong extensionis it possible to recall or pickup even with the cisco attendant console?
@joe - with other pickup will i be able to answer exact extension? and also other pickup only support 10 groups.
thanks for the replies.
10-23-2010 08:46 AM
Hi Tharaka,
Sadly, this feature is only available in CME and the "new" CUCM Attendant Consoles, so the only way to control this is via using a Consult Transfer
rather than doing "Blind" Transfers
Or
Transfer Reversion (Call Recall) which is available on the Cisco Unified Business Attendant Console and the and Cisco Unified Department Attendant Console ;
This allows a transferred call to revert back to the department administrator so that it can be answered and then transferred to a new destination.
Cisco Unified Business Attendant Console and Cisco Unified Department Attendant Console
Call-Transfer Recall
The Call-Transfer Recall feature in Cisco Unified CME 4.3 and later versions returns a transferred call to the phone that initiated the transfer if the destination is busy or does not answer. After a phone user completes a transfer to a directory number on a local phone, if the transfer-to party does not answer before the configured recall timer expires, the call is directed back to the transferor phone. The message "Transfer Recall From xxxx" displays on the transferor phone.
The transfer-to directory number cannot have Call Forward Busy enabled and cannot be a member of any hunt group. If the transfer-to directory number has Call Forward No Answer (CFNA) enabled, Cisco Unified CME recalls the call only if the transfer-recall timeout is set to less than the CFNA timeout. If the transfer-recall timeout is set to more than the CFNA timeout, the call is forwarded to the CFNA target number after the transfer-to party does not answer.
If the transferor phone is busy, Cisco Unified CME attempts the recall again after a 15-second retry-timer expires. Cisco Unified CME attempts a recall up to three times. If the transferor phone remains busy, the call is disconnected after the third recall attempt.
The transferor phone and transfer-to phone must be registered to the same Cisco Unified CME, however the transferee phone can be remote.
Hope this helps!
Rob
