Is there a way to add, delete or change a FAC code via CLI in CUCM?
davazquezcisco
Hi everyone,
I was wondering if it is possible to add, delete or change a fac code(or client matter) via CLI?
I know how to do it via BAT tool, but I want to do it via CLI(if it's possible).
I´m using CUCM 6.
I'll really appreciate your comments.
Thanks..
Dave.
There are no instructions n how to do this and we do not support doing any kind of changes to the DB via CLI unless instructed by TAC.
If you still want to do so, read the data dictionary for your CUCM version and work your CLI queries, again, if anything happens and the DB becomes corrupted or you have undesired results, we won't provide any level of support.
Previously I mentioned which are the supported methods for adding elements to the DB, I encourage you to use any of them.
java
if this helps, please rate
Jaime Valencia
In theory, yes, but we do not support doing so.
Either you use BAT, CCMAdmin or AXL for support.
java
www.cisco.com/go/pdihelpdesk
java
davazquezcisco
Hi javalenc...
Thank you for your response.
May I ask why did you say "In theory, yes, but we do not support doing so."?
Is it too complicated to explain?
I would like to know if it is possible and how to do it, because I want to make a script to manipulate this FAC Codes.
If you know, I'll appreciate it.
Regards.
Dave
java
I got the data dictionary and I think I can work with.
Thank you very much for your support.
Regards!
