ISDN AND MGCP CUCM
kennedymacharia
Hi everyone,
I am struggling with configuring an E1 line for use with cucm on an an mgcp gateway. I have a BE6000s which I have basically re-used most of the pre-configurations that were there. I have a I port E1 card and an FXO card for my pstn access on my gateway. I have configured mgcp and the all the ports have registered properly. My challenge is I cant make a call out through the E1 line. I have even tried to add dial-peers for the E1 card but I still get a busy signal. i thought with MGCP the CUCM should control everything? I have pasted my config. what Im I missing? Kindly assist. Thanks in advance.
Current configuration : 11926 bytes
! Last configuration change at 19:59:13 GMT Thu Sep 1 2016 by cisco
! NVRAM config last updated at 19:59:14 GMT Thu Sep 1 2016 by cisco
version 15.5
service compress-config
service sequence-numbers
hostname BE6000S
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
enable secret 5 $1$Ansx$MWLpHHKYquglQG9DIokMG1
aaa new-model
aaa authentication login default local
aaa session-id common
ethernet lmi ce
clock timezone GMT 3 0
network-clock-participate wic 0
ip dhcp excluded-address 172.27.199.1 172.27.199.31
ip dhcp pool BE6000S-Preconfigured-S1
import all
network 172.27.199.0 255.255.255.192
default-router 172.27.199.1
option 150 ip 172.27.199.11
dns-server 172.27.199.1
domain-name ciscolocal.com
lease 0 2
ip domain name ciscolocal.com
ip host ucn1.ciscolocal.com 172.27.199.12
ip host plm.ciscolocal.com 172.27.199.11
ip host imp1.ciscolocal.com 172.27.199.13
ip host _cisco-uds._tcp.ciscolocal.com srv 0 1 8443 ucm-pub.ciscolocal.com
ip host _cuplogin._tcp.ciscolocal.com srv 0 1 8443 imp1.ciscolocal.com
ip host ns.ciscolocal.com 172.27.199.1
ip host ntp.ciscolocal.com 172.27.199.1
ip host pcp.ciscolocal.com 172.27.199.10
ip host ucm-pub.ciscolocal.com 172.27.199.11 2001::172:27:199:11
ip host s1-dgw.ciscolocal.com 172.27.199.1
ip host s1-ns.ciscolocal.com 172.27.199.1
ip host s1-vgw.ciscolocal.com 172.27.199.1
ip host s1-ntp.ciscolocal.com 172.27.199.1
ip host s1-cimc1.ciscolocal.com 172.27.199.2
ip host s1-esxi1.ciscolocal.com 172.27.199.4
ip multicast-routing
ip cef
no ipv6 cef
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-142722845
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-142722845
revocation-check none
rsakeypair TP-self-signed-142722845
crypto pki certificate chain TP-self-signed-142722845
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31343237 32323834 35301E17 0D313630 37323831 36313034
355A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3134 32373232
38343530 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
CFF18776 9977CA09 54767E37 AF433ADF 5BBC368A 3D085A55 90D79227 ECF434CF
C8F8FC9D 20F1CB37 85B08C0C 06C98303 04BCB56F A12977F3 45F492E8 F8A06505
5A64CEE0 DBDD3AB7 351F09CA 5AAEE7D1 BE78622A 63969F95 653C8FEB A3D8FA69
3A472E35 DD3E4EA4 C32F2541 8476CBE0 D4351733 AAB73DFC 5A31B594 F848C33F
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 168014D7 6DF796ED 2D9D3146 5D78D5E2 885CDA2C 6AA71030 1D060355
1D0E0416 0414D76D F796ED2D 9D31465D 78D5E288 5CDA2C6A A710300D 06092A86
4886F70D 01010505 00038181 00985097 652A29AD 4FE3996F 0A0B8562 DBCD6C36
F65ECDE7 EEF40575 5AD69B41 BF6B9576 F3062F61 61448A6E 167D1067 3E5922D4
447AA1EC D1A83FFA CBA0A2A5 3FBAD1F1 0CBED1B0 C7217531 854AECD4 96DC09F7
ED07DD1E C386D077 12AF7BF2 0D285757 4DC0CC0D 0506A227 E58CB2D2 7205D24F
F7289A4C 45ADD8B0 6F4BD692 73
quit
voice-card 0
voice service voip
ip address trusted list
ipv4 172.27.199.11
ipv4 172.27.199.14
ipv4 172.27.199.15
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no fax-relay sg3-to-g3
modem passthrough nse codec g711ulaw
sip
bind control source-interface BVI1
bind media source-interface BVI1
asymmetric payload full
no update-callerid
voice class uri ucm sip
host ^172.27.199.1[145]$
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 ilbc
voice translation-rule 1
voice translation-rule 2
rule 1 /^.*\(...\)$/ /1\1/
voice translation-rule 3
rule 1 /^.\(...\)$/ /5551234\1/ type any national plan any isdn
voice translation-rule 4
rule 1 /^\+1\(...\)/ /\1/ type any national plan any isdn
rule 2 /^\+1\(.*\)/ /1\1/ type any national plan any isdn
rule 3 /^\+\(.*\)/ /011\1/ type any international plan any isdn
voice translation-profile PSTN-to-UCM
translate calling 1
translate called 2
voice translation-profile UCM-to-PSTN
translate calling 3
translate called 4
fax interface-type fax-mail
license udi pid CISCO2921/K9 sn FJC2031A17M
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
archive
log config
logging enable
logging size 600
hidekeys
username cisco privilege 15 password 0 cisco
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address dhcp
ip pim sparse-dense-mode
ip nat outside
ip virtual-reassembly in
ip igmp version 3
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface ucse1/0
description Internal interface connected to UCSE Port 0
ip unnumbered BVI1
service-module heartbeat-reset disable
imc ip address 172.27.199.2 255.255.255.192 default-gateway 172.27.199.1
imc access-port shared-lom console
bridge-group 1
interface ucse1/1
description Internal switch interface connected to UCSE Port 1
no ip address
interface Vlan1
no ip address
interface BVI1
description Bridge interface providing access to router and UCSE module.
ip address 172.27.199.5 255.255.255.192 secondary
ip address 172.27.199.1 255.255.255.192
ip nat inside
ip igmp version 3
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.0.0.7
ip route 0.0.0.0 0.0.0.0 192.168.16.2
snmp-server community public RO
access-list 23 permit 10.0.0.0 0.255.255.255
access-list 23 permit 172.16.0.0 0.15.255.255
access-list 23 permit 192.168.0.0 0.0.255.255
access-list 100 permit ip 172.27.199.0 0.0.0.255 any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
voice-port 0/0/0:15
cptone KE
voice-port 0/1/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone
no battery-reversal
signal groundStart
no vad
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 1000
caller-id enable
voice-port 0/1/1
pre-dial-delay 0
no battery-reversal
signal groundStart
no non-linear
no comfort-noise
timeouts interdigit 3
bearer-cap Speech
caller-id enable
voice-port 0/1/2
pre-dial-delay 0
no battery-reversal
signal groundStart
no non-linear
no comfort-noise
bearer-cap Speech
caller-id enable
voice-port 0/1/3
pre-dial-delay 0
no battery-reversal
signal groundStart
no non-linear
no comfort-noise
bearer-cap Speech
caller-id enable
mgcp
mgcp call-agent 172.27.199.11 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
ccm-manager music-on-hold
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager config server 172.27.199.11
dial-peer voice 99901993 pots
service mgcpapp
port 0/1/3
dial-peer voice 99901990 pots
service mgcpapp
port 0/1/0
dial-peer voice 99901991 pots
service mgcpapp
port 0/1/1
dial-peer voice 99901099 pots
service mgcpapp
port 0/1/0
dial-peer voice 99901199 pots
service mgcpapp
port 0/1/1
dial-peer voice 99901992 pots
service mgcpapp
port 0/1/2
dial-peer voice 99901399 pots
service mgcpapp
port 0/1/3
dial-peer voice 99901299 pots
service mgcpapp
port 0/1/2
dial-peer voice 1 pots
service mgcpapp
port 0/0/0:15
dial-peer voice 3 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
sip-ua
timers trying 100
gatekeeper
shutdown
telephony-service
max-conferences 8 gain -6
transfer-system full-consult
banner exec ^C
Cisco Business Edition 6000S
You must create a new user name and password using Cisco CP or the following
CLI command before continuing to use this system:
username <newusername> privilege 15 secret <newpassword>
WARNING: This system includes a Cisco UCS server module which MUST be shut
down (power button is orange) before removing power. Failure to shut down
gracefully may result in data loss or corruption.
For further information, refer to the BE6000S installation guide:
www.cisco.com/go/be6ksig
^C
banner login ^C
This appliance has been preconfigured for your convenience. You may manage
this system locally via console, or by connecting to 172.27.199.1 through
interface GigabitEthernet 0/1 using Telnet, SSH or Cisco Configuration
Professional (Cisco CP) via HTTP. DHCP is enabled for client configuration.
For initial access, log in with user name "admin" and password "password".
These credentials may be used for the first log in ONLY. If you log out
without creating a new user name, you may not be able to log in again.
^C
line con 0
privilege level 15
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
speed 9600
flowcontrol software
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
ntp master 3
ntp update-calendar
ntp server 3.ciscosb.pool.ntp.org
ntp server 2.ciscosb.pool.ntp.org
ntp server 1.ciscosb.pool.ntp.org
ntp server 0.ciscosb.pool.ntp.org
end
Most likely, use Dialed Number Analyzer in CUCM to see how the call is routed from CUCM perspective.
5 Replies 5
Chris Deren
Yes, with MGCP the full dial plan is configured on CUCM. Can you post "debug isdn q931" for the non-working call along with "debug voice ccapi inout"? This will show us if the call is even making it to the GW and then PRI.
thank you for the reply. I have no output on the debugs. does that mean my problem is on the cucm? but my E1 card is registered.
Thank you Deren I was able to solve this the DNA was of help. Now I am able to make outgoing calls but I still cannot make incoming calls. Debug Q931 show Sending Complete Bearer Capability i = 0x8090A3 Standard = CCITT Transfer Capability = Speech Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA1838B Preferred, Channel 11 Calling Party Number i = 0x2183, '717792733' Plan:ISDN, Type:National Called Party Number i = 0xC1, '0532020551' Plan:ISDN, Type:Subscriber(local) 001034: Sep 7 11:47:14.735: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8081 Cause i = 0x8081 - Unallocated/unassigned number. Do you have any idea what could be causing this? I have DID 0532020XXX and I have configured significant digits to 3
Verify the partition assigned to the DNs is listed in the CSS referenced by the PRI port.
