08-24-2018 08:53 PM
My company has a CUCM 11.5, ISR4321
ISR4321 has 2 E1 cards, two E1 different telecommunications companies
Can I use the calling number of CUCM or ISR4321,Separate to different E1 dial out.
EX:
1001 call out 222510628,1001 to E1-1 Port
1002 call out 222510628,1002 to E1-2 Port
Can I perform at CUCM or ISR?
Or two can do it?
Thank you.
08-25-2018 10:13 AM - edited 08-25-2018 10:22 AM
Sure. Modify the called number on the CUCM Route Pattern to prefix a digit that will uniquely match different outbound dial-peers of the appropriate E1 port. For example, CUCM could prefix “A” to the called number for calls that should be sent out the first port and “B” for the second port. Just be sure the prefix isn’t passed to the carrier (it shouldn’t be as an explicitly matched digit on a POTS dial-peer). Of course this also means you need different CSS, Partition, and Route Patterns in CUCM to add the prefix in the first place.
08-26-2018 07:56 PM
