06-21-2016 03:50 PM - edited 03-19-2019 11:16 AM
one of the user has to dial very fast on Cisco 6941 , is it possible to increase the time duration between pressing one digit and the next digit ? so that it doesn't disconnect and advise to try again ...
Solved! Go to Solution.
06-21-2016 06:43 PM
You need to mention if you're using CUCM or CME and version if you require assistance.
06-22-2016 07:24 AM
The interdigit timeout is the T302 timer in service parameters, make sure the value is what you require, the default is 15 seconds.
06-21-2016 06:43 PM
06-21-2016 08:24 PM
My Bad ,
06-22-2016 07:24 AM
