Jabber MRA with external Certificates
expert,
can someone guide me on steps how to apply external ceritificate , such as : Go Daddy  certificates to Jabber MRA?
thanks,
K
4 Accepted Solutions
You can just generate the CSR in your expressway and then have it signed by your public CA, there is no real need create the CSR with openssl, unless you want to, then you would need to upload the key and certificate.
java
if this helps, please rate
Might want to do some reading on CSR and public CA to understand this
https://www.sslshopper.com/what-is-a-csr-certificate-signing-request.html
https://en.wikipedia.org/wiki/Certificate_signing_request
Most Cisco products only allow you to generate a CSR, the private key never leaves the server, and you only upload the signed request.
On a VCS, you can also generate your own private key and CSR, and upload both of them, as in the example from the guide using openssl
If you're going to use MRA for IP Phones, make sure to read the doc on what public CA root certs are uploaded on the devices, as only those will work. If this is only for Jabber, most public CA root certs are already in most devices.
java
Hi Karen,
I would probably go for Godaddy certificate, I think they have the best deal i believe.
You can go for a UCC certificate and then include all the FQDN as SAN's in a single certificate.
They have options for 5 SAN or 10 SAN's excluding the CN of the certificate which basically means you can have in total 6 or 11 different FQDN's.
We recommend this to all our customer.
It is also supported by the devices registering over MRA for e.g. 7800 or 8800.
Alok
10 Replies 10
Chris Deren
Thanks Chris,
I read all the link, is this section " Appendix 2: Certificate Generation using OpenSSL "  ?
Is the real implement is really text book following all in Appendix 2 will just work ?
or maybe you have notes from past implementation that you can share here?
thanks,
K
java
Hi Jamie,
"then have it signed by your public CA "  , means just send to Go Daddy support  to sign and they will send us back with file to upload to Exp-E?
what is better public CA beside GoDaddy that you recommend or used before?
thanks,
K
java
Thanks Jamie,
where I read this  ?
K
See here
http://www.cisco.com/c/en/us/support/collaboration-endpoints/unified-ip-phone-8800-series/products-technical-reference-list.html
java
I see thanks
Thanks Jaime,
where do I find this ?
best,
K
Hi Karen,
Alok
