Jabber Question on ‘Use my computer for calls’
cloudconnected
I’d like to find out if there is a way on Jabber to have ‘Use my computer for calls’ set on all PC’s a user might log into?
We have an exec who moves between PC’s and he has to select this every time he moves to the other PC to get calls coming in to it.
Can it default to this when you log in?
Jaime Valencia
You can configure the preferred mode via the .xml
java
if this helps, please rate
