Let's Encrypt Certificate automation?
ruudvanstrijp
Level 4
Level 4
It's currently already possible to assign a Let's Encrypt certificate to Expressways (and I guess also for CUCM, etc), by manually requesting a certificate using zerossl.com for example. However, I see Cisco is one of Let's Encrypt's Platinum donors: https://letsencrypt.org/sponsors/
With this in mind, wouldn't it be possible for Cisco to integrate Let's Encrypt into their UC platform? This would especially be great for the Expressway-E servers, which require a public signed certificate.
Ruud
Jaime Valencia
If you want to bring this idea to the BU, you'd need to do so via your SE/AM or submit a PER.
If you're asking if there are plans to do so, that would be roadmap information which is NDA and you'd need to post in the partner communities or ask via your SE/AM
java
if this helps, please rate
this is a confirmed option in Expressway's next release after 8.11 I am told.
CCIE-Collaboration #24527
Thanks Haffi, that answered my question :-)
Hope you are doing well.
BR Rolf
