Licensing Warning for changing Web Security
deepak.puranik
I planning to change Web Security by following command
admin:set web-security
and getting Licensing Warining message
WARNING: Changing this setting will invalidate software license
         on this server. The license will have to be re-hosted.
Will my system function normal if my license is invalidate, or till I get new license file? I have more than 5 CUCM nodes and 1K + IP phones in this cluster.
will.alvord
Level 5
Level 5
You'll just have to go through the rehosting process, but I believe the grace period is 30 days.  You can go through the answer file generator (http://www.cisco.com/web/cuc_afg/index.html) to get your new license mac and have everything ready prior to your change.
