Missing CUE messages
leslie-meade
Intermittent issue where external callers hear the users prompt and leave a message but never appears in the mailbox.
Other times it does. Mailbox has only one message in it and the size is at 9%. It has happened to everyone at this site.
Any ideas on where to start trouble shooting this issue ?
Leslie
Hey,
can the external caller record the message or he hears that the mail box is full?
i think u r using the cisco cme with cue?
to start troubleshoot:
Cue# show voicemail mailboxes
Cue# show voicemail usage
Cue# show voicemail limit
Cue# show voicemail detail user (type the user name)
With the above commands you can view the total mail box size, users mailbox with the percentage used, limits and also don`t forget to use
Cue# show software license
update me with the above so i can help you.
regards,
No it is a callmanager cue intergration. (7.06 CUE)
People get into voicemail and hear the message to leave a message.
they leave a message
then it is a hit and miss if the user gets it delivered into the mailbox.
It just "disapears" to be never found
other times the message gets delivered and everything is good
