ML: Sa Sub Conversation -> Conversation Style dropdown empty with ENC
sbeukenkamp
The Dutch language has the same problem as described in bug CSCsb16144
Cheers
Sijbren
lindborg
Yes, looking at the Conversation table in the UnityDB database you can see the only languages defined are French, German, Japanes and English for the conversation names - you can add your own entries for each with the appropriate language code if you want to get adventerous... or you can change the language in IE long enough to change the conversation and then change it back, or you can use BulkEdit to apply the conversation to users without switching your IE language.
