05-05-2008 02:41 PM - edited 03-18-2019 08:53 PM
Can someone please point me in the right direction.
I am looking for the configuration guide for Mobility Manager for CUCM6
I am having issues when calling into voice access from the mobile phone, authenicating OK, then pressing "1" to dial an extension number. The call clears down as soon as the # is entered after the extension number.
Can someone please help
Steve
05-05-2008 05:33 PM
you can find the guide here:
Maintain and Operate Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
javalenc
if this helps, please rate
02-09-2009 01:34 AM
Steve,
Did you managed to resolve as I have the same problems
02-09-2009 01:39 AM
check your CSS on the Remote Destination
also make sure your codec's negotiated ok
02-09-2009 01:52 AM
Steve,
I did not configure any css and partition.mobile connect works fine.
02-09-2009 01:55 AM
I found MVA uses the CSS on the RD to allow calls through option "1", (not the reroute CSS)
02-09-2009 01:59 AM
thks .but all my css and partition are set to "none".do you thk these will affect the option "1" routing.I have no problem calling out from phones.Call options 1 call internal extension?
02-09-2009 02:04 AM
Try using DNA with the RD Extension number and ensure you can make all necessary call types
02-09-2009 02:13 AM
thks .In fact i have a ip communicator with the RD extension which have no problems making outside calls.
Have a pleasant day !!
