Mobility Manager Configuration Guide for CUCM 6.X
steve-parrish
Can someone please point me in the right direction.
I am looking for the configuration guide for Mobility Manager for CUCM6
I am having issues when calling into voice access from the mobile phone, authenicating OK, then pressing "1" to dial an extension number. The call clears down as soon as the # is entered after the extension number.
Can someone please help
Steve
8 Replies 8
Jaime Valencia
you can find the guide here:
Maintain and Operate Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_maintenance_guides_list.html
javalenc
if this helps, please rate
java
shingphing_2
Steve,
Did you managed to resolve as I have the same problems
check your CSS on the Remote Destination
also make sure your codec's negotiated ok
Steve,
I did not configure any css and partition.mobile connect works fine.
I found MVA uses the CSS on the RD to allow calls through option "1", (not the reroute CSS)
thks .but all my css and partition are set to "none".do you thk these will affect the option "1" routing.I have no problem calling out from phones.Call options 1 call internal extension?
Try using DNA with the RD Extension number and ensure you can make all necessary call types
thks .In fact i have a ip communicator with the RD extension which have no problems making outside calls.
Have a pleasant day !!
