Multi-vendor Conferencing
Suresh Varghese
can anyone please advise whether it will be possible for me to host a meeting and allow users from different location in my domain to connect via different applications
e,.g. one meeting where my roaming O365 users can join thru Skype for business in HQ, branch office users using polycom and few brnahces using other VC units like Panasonic HDVC etc.
Can this be done thru UCM??
Apologies if the question is confusing, am basically new to the UC landscape
regards
SV
Yes if you have integration between these systems. For example, a user with
cisco phone registered in cucm hosted and bridge. Now the bridge will be
allocated by CUCM and opened for other users to join. If you have a user in
O365 with S4B and O365 has SIP integration to CUCM then the user with S4B
can dial the bridge number and join the call. This is the same for user
dialing from PSTN or a user behind a polycom system.
As long they are integrated with UCM using SIP or H323 then they can dial
the bridge and join the call from.
Hey Baqari
many thanks for the details, appreciate the same
will look into the technicalties and get back to you if i have any queries.
many thanks
SureshV
