MWI issues with CME/CUE SIP integration
bkhanal1971
Level 3
Level 3
I have CME 10.5 and CUC 10.5,newly installed. Everything seems to be working fine except that the MWI is not working. I have MWI turned on in each DNs as well as voicemail pilot number in the voice register global. I also created a dialpeer.
I have done the required work in telephony integration related in the CUC including ports, port groups etc. There are a few ports that are configured for MWIs. Everything looks ok but still MWI is not working. Voicemails are there in the test mailboxes.
Not knowing what went wrong, I decided to post here. If somebody could give me the checklist where I should be looking to resolve this issue,that would be great.
Thanks, Khanal
14 Replies 14
Vivek Batra
With debug ccsip messages, can you see notify message from cuc?
Did you configure mwi unsolicited command under sip-ua mode?
- Vivek
I have mwi-server ipv4:........unsolicited command under sip-ua
I haven't done the ccsip messages debug yet but i will see if I can find something from the output.
Thank you Vivek.
I can't see any issue with the configuration you've provided so far and it should simply work. Can you please share the ouput of show run to identify further?
- Vivek
Hi Vivek: Here is the relevant portion of show run command. I even tried sccp integration and when i fired "mwi relay" i got the error that says "Problem starting mwi application"
I can't figure out any issue with the configuration. I suggest you to check with TAC unless any of my friend here has to say on this.
- Vivek
I got it working finally. I had to eliminate long string of parameters for mwi-server command and just put mwi-server ipv4:ip unsolicited and mwi lights are on now. Thank for all your help Vivek.
Thanks for updating the results Khanal.
- Vivek
Hello
I have the same error
You can check that I wrong ??
I have days without success =(
Regards.
just put "mwi-server ipv4:address unsolicited" under sip-ua and see if that helps.
Hello
He removed the command
sip-ua
no mwi-server ipv4:172.16.1.2 expires 3600 port 5060 transport udp unsolicited or
no sip-ua
I place
mwi-server ipv4:172.16.1.2 unsolicited
but it still appeared in settings
sip-ua
Because I still appears ??
As he put it correctly ??
Regards.
I have attached the output of debug ccsip pmessages. Looks like MWI is working but neither I see the light turned or or the voicemail icon. Any help would be a great help.
Thanks, Khanal
I can see notify coming from cuc but there is no 200 OK from CME.
Can you check cuc ip address is correct in mwi command? You can also verify the SIP bind interface is correct and that is where cuc should be sending notify.
- Vivek
Hi Vivek,
Everything looks good in terms of configuration per your advise. I have used subinterface for sip bind
such as:
bind control source-int gig1/0/1.32
bind media source-int gig1/0/1.32
And the CUC ip address is correct in mwi command
and MWI config lines looks like this:
sip-ua
timers buffer-invite 800
mwi-server ipv4:x.x.x.x (CUC ip) expires 3600 port 5060 transport tcp unsolicited.
My problem still remains as it is.
I know this is very old but I am having the same issue.  I wonder if anyone can help.  I have tried all three methods.  I can dial the MWI number and the ext and light and unlight the phone, but the trace doesn't show the sip number including the MWI prefix.
I am running CME and CUE n a UC500 with 8.6.5 code.
Sent:
INVITE sip:1000@10.200.11.251:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.11.250:5060;branch=z9hG4bK1A12614
Remote-Party-ID: <sip:1205@10.200.11.250>;party=calling;screen=no;privacy=off
To: <sip:1000@10.200.11.251>
Date: Wed, 04 Oct 2017 17:37:16 GMT
Call-ID: 7FD859DF-A86111E7-8AFC940B-57223D2B@10.200.11.250
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2144845239-2824933863-2331546635-1461861675
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1507138636
Contact: <sip:1205@10.200.11.250:5060>
Diversion: <sip:1205@10.200.11.250>;privacy=off;reason=no-answer;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 414 5984 IN IP4 10.200.11.250
s=SIP Call
c=IN IP4 10.200.11.250
t=0 0
m=audio 18782 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
000668: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 04 Oct 2017 17:37:17 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1507138637
Expires: 180
Content-Length: 249
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
000669: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
000670: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:1000@10.200.11.251>;tag=ds218b77f7
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:1000@10.200.11.251:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 7FD859DF-A86111E7-8AFC940B-57223D2B@10.200.11.250
000671: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 133
Call-Info: <sip:10.200.11.251:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 7769615 2 IN IP4 10.200.11.251
s=SIP Call
c=IN IP4 10.200.11.251
t=0 0
m=audio 21116 RTP/AVP 0
000672: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1000@10.200.11.251:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.200.11.250:5060;branch=z9hG4bK1A272E
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
000673: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:1205@10.200.11.250:5060 SIP/2.0
Via: SIP/2.0/UDP 10.200.11.251:5060;branch=z9hG4bKGtM1eiuZu4D04FJQaYGdGw~~273
Max-Forwards: 70
To: <sip:1205@10.200.11.250>
CSeq: 1 SUBSCRIBE
Content-Length: 0
Expires: 3600
Event: telephone-event
000674: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <sip:1205@10.200.11.250>;tag=345B36C-50E
CSeq: 1 SUBSCRIBE
Content-Length: 0
Expires: 3600
000675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:1000@10.200.11.251:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.200.11.250:5060;branch=z9hG4bK1A31A2
CSeq: 102 NOTIFY
Max-Forwards: 70
Subscription-State: active
Content-Length: 0
000676: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 102 NOTIFY
Content-Length: 0
Allow-Events: refer
Allow-Events: message-summary
000677: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:1000@10.200.11.251:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.200.11.250:5060;branch=z9hG4bK1A41A90
Max-Forwards: 70
Timestamp: 1507138651
CSeq: 103 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=715,OS=114400,PR=617,OR=98243,PL=0,JI=0,LA=0,DU=14
Content-Length: 0
000678: //950/7FD7BDB78AF8/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 103 BYE
Content-Length: 0
000679: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.200.11.250:5060;branch=z9hG4bK1A5D2E
CSeq: 104 NOTIFY
Max-Forwards: 70
Date: Wed, 04 Oct 2017 17:37:31 GMT
Subscription-State: terminated
Content-Length: 0
000680: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 104 NOTIFY
Content-Length: 0
Allow-Events: refer
Todd
