Need notification on Unity Failover
tarun.pahuja
Folks,
I have 2 unity servers ( primary and secondary). I have notification turned on under diagnostics. Is their any option that i can choose that would inform me if one of the unity server failed. Some time the unity server goes doen with the Main AV service stopping, i was hoping if their is an even which was directly tied to the failover process.
milucero
You can use the Event Monitoring tool, http://www.ciscounitytools.com/App_EMS.htm
To notify you of a failover. Setup a trigger for event
1033, Information event, on the primary, source is CiscoUnity_DSAD and do the same thing on the failover, but for information event 1050, source is CiscoUnity_NodeMgr.
These two events only occur when a filover occurs.
Mike
