NEED TO TURN OFF SELF-VIEW WHEN NOT IN A CALL
kevin.murray
Is there a way to turn off the camera (self-view) while sharing data to the screen while NOT in a call? The self-view covers up part of the data slide being presented. It can be moved around the screen but not dismissed. I work at a children's hospital where we've installed one of these units in the Executive Boardroom. Cytology stains, x-rays, etc. are all partially obscured by the self-view. The only way I've found so far is to go into Whiteboard mode while sharing data via HDMI cable, but this is only a slight improvement as now the whiteboard icons are obstructing the slide view. The only other (unacceptable) option is to put the unit in a dummy call with only one participant. This seems basic, as our Polycom equipment is able to do this but our Cisco equipment cannot. Any advice that isn't a 3-stage workaround?
kevin.murray
I should note, we are using a Cisco Webex Board 70s.
Possibly you might be affected by this defect. https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvz53702
Response Signature
