04-22-2017 03:24 AM - edited 03-19-2019 12:21 PM
Hi everyone
i've been struggling with a cisco 2811 router and fxo lines which is very strange i think . every 1 week , 2 FXO ports of voice gateway become off-hook until i administratively shutdown and the no shutdown the ports . i dont know what is a exact problem ..the output of ports configuration and command are shown below...also i attach the screenshot the problem .
voice-port 0/0/1
translation-profile incoming PSTN-I
translation-profile outgoing PSTN-O
supervisory disconnect dualtone mid-call
supervisory dualtone-detect-params 1
echo-cancel coverage 24
echo-cancel mode 2
no vad
no comfort-noise
cptone IE
timeouts call-disconnect 3
timeouts wait-release 5
connection plar 219
impedance complex2
description 26450120
caller-id enable
voice-port 0/1/0
echo-cancel mode 2
no vad
no comfort-noise
cptone IE
connection plar opx 200
impedance complex2
description 22828955
caller-id enable
thanks in advance :)
Solved! Go to Solution.
04-23-2017 03:02 AM
Can you try the below:
under the voice-port try to add
No batter-reversal
if that doesn't fix it, try to
voice-card 0
no local-bypass
Alok
04-22-2017 01:26 PM
I don't know the answer. I am suspicious of a software issue since it seems to work fine for a week and then the issue happens. If it was me I would start by upgrading the IOS to a gold star release such as 15.1.4M12a.
04-22-2017 10:11 PM
thank you philip for your response;
i think i should upgrade it first ..but i dont know how can i deal with licensing part ....so you think my configuration is not a problem ? do you think maybe PVDM causes the problem ??
04-22-2017 10:59 PM
I don't know. I would try a software upgrade first.
04-23-2017 03:02 AM
No batter-reversal
voice-card 0
no local-bypass
Alok
04-25-2017 11:52 PM
thank you Alok
i am going to issue these commands and i will inform you about the result . but could you please tell me about the second command ? (Voice-card )
is this command working on FXO cards ??
05-14-2017 11:20 PM
Dear Alok
i've not had this problem anymore after these command you told me ...i think the issue is resolved. thank you so much
