Nortel CS1000 with Unity VM integration
colin.mcnamara
Level 4
Level 4
I have a request to integrate a Nortel CS1K with a new Cisco Unity server (VM only, no CallManager). I cannot find any integration documents listed @ cisco. Has anyone successfully integrated these systems? And if so, do you have any integration documents that I can refer to?
Thank you ,
--Colin
sopayne
Hi Colin,
I couldn't find any reference to that particular PBX as being a supported integration option for Unity:http://cisco.com/en/US/products/sw/voicesw/ps2237/prod_system_requirements_hardware09186a0080531f2a.html
You may want to contact your Cisco Partner or Cisco Systems Engineer to look into getting this particular PBX on the supported list.
I hope this helps.
Yeah, I couldn't find anything in that document either. I was secretly hoping that maybe Jeff was lurking the forums and had seen one of these go through.
Thanks you,
--Colin
colin.mcnamara
Level 4
Level 4
I got the answer, the CS1k can be integrated by adding a digital handset line card, and using a PIMG integration to the Unity server.
