NTP Startum move to failed when i add another NTP
Paulo Castro
Hello.
I try to add another NTP server in my CUCM, but when i add, my ntp_stratum turn unspecified and in ntp_stratum test return Failed.
I have two NTP's in different Switches (Cisco 3850) with the same clocktime and same configurations.
Anyone have can help me?
Thank you.
Could you check the connectivity between UCM and NTP server ?
Also be advised that the windows as an NTP server is not supported for UC
As the diagnostic test simply tells that it failed, so maybe the connectivity issue.
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
