01-08-2007 12:22 PM - edited 03-18-2019 06:47 PM
Unity 4.1.3, Unified messaging.Exchange 2000.
I deleted user by mistake (hit the wrong button!).
If I go to put them back in get error message "alias already exists".
As I dont have any control over the Windows or Exchange environments what do I need to get reset, by the server team, and is it Windows or Exhange 2000.
01-08-2007 12:31 PM
If you deleted the user only from Unity it should remain in the Active Directory, instead of adding it again why don't you try importing it.
//Jorge
01-08-2007 02:10 PM
You can import them back in, the voicemails will still be there, but they will have lost all personal settings, such as recorded name, alternate greeting, pin, etc.
cheers
01-09-2007 11:10 AM
Thanks, I guess that was a bit of an easy answer to a newb question!
Sorry but I havent touched Unity for a long time and certainly not in a unified setup.
Thanks again.
