OS User Problems
Ahochau
A "helpful" contrator built the CUCM environment.  When they were done they went in and enabled password complexity and expired the service account password.  I know I can use the set password admin to change the os admin password, but I am not sure that is the account I am using.  So, what I am looking for is a way to list the users configured for platform administration, and then how to reset the password for the user I have logged in with.  The only way I have found to change a user password in the past is to delete and re-create the account.  I've checked the CLI Admin guide, will look again.
Thanks!
Tried "show account" as that works on 8.6, but not so lucky on 10.5
admin:show account
Executed command unsuccessfully
Incomplete command entered
admin:show account
admin:show accountlocking  ?
Syntax:
show accountlocking
no parameters are required
admin:show account
admin:show
      show Login*
      show accountlocking
      show cert*
keglass
Level 7
Level 7
I recommend you also post this to the Cisco Support Community for additional feedback and information.
Hope this helps resolve your issue.
Kelli Glass
Moderator for Cisco Customer Communities
Sorry, too many communities to keep track of.......
