02-05-2018 02:17 AM - edited 03-19-2019 01:07 PM
I am facing an issue while configuring MGCP gateway. I am trying to make an outbound call from IP phone through FXO port. I'm getting busy tone on dialing a number. Please find the below gateway logs.
Feb 5 09:53:26.290: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x4B112DB8, Interface Type=6, Destination=08870648865, Mode=0x9,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screeni ng=Not Screened, Presentation=Allowed),
Called Number=08870648865(TON=Unknown, NPI=Unknown), Calling Translated=FALSE ,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Appl ication Call Id=A000000001cb3c74000000F5)
Feb 5 09:53:26.290: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 5 09:53:26.290: :cc_get_feature_vsa malloc success
Feb 5 09:53:26.290: cc_get_feature_vsa count is 1
Feb 5 09:53:26.290: :FEATURE_VSA attributes are: feature_name:0,feature_time:12 46324776,feature_id:254
Feb 5 09:53:26.290: //1631095/3EC5E105805C/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Feb 5 09:53:26.290: //1631095/3EC5E105805C/CCAPI/ccCallSetContext:
Context=0x4CF3AE98
Interface=0x4AA0118C, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=A000000001cb3c74000000F5)
Feb 5 09:53:26.294: :cc_get_feature_vsa malloc success
Feb 5 09:53:26.294: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 5 09:53:26.294: cc_get_feature_vsa count is 2
Feb 5 09:53:26.294: :FEATURE_VSA attributes are: feature_name:0,feature_time:1246324328,feature_id:255
Feb 5 09:53:26.294: //1631096/3EC5E105805C/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
Feb 5 09:53:26.294: //1631096/3EC5E105805C/CCAPI/ccCallSetContext:
Context=0x4CF3ADE8
Feb 5 09:53:26.298: //1631096/3EC5E105805C/CCAPI/cc_api_call_connected:
Interface=0x4AA0118C, Data Bitmask=0x0, Progress Indication=NULL(0),
Connection Handle=0
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Feb 5 09:53:26.302: //1631095/3EC5E105805C/CCAPI/cc_api_call_proceeding:
Interface=0x4B112DB8, Progress Indication=NULL(0)
Feb 5 09:53:36.302: //1631095/3EC5E105805C/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x4B112DB8, Call Id=1631095
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Feb 5 09:53:36.302: //1631096/3EC5E105805C/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Feb 5 09:53:36.302: //1631095/3EC5E105805C/CCAPI/ccCallDisconnect:
Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
02-05-2018 06:43 AM
Is inbound call working? Is the POTS line Ground or Loop start? Have you tried both?
Can you post "debug vpm signal"?
02-05-2018 10:46 PM
I have configured the FXO port type as ground start and only for outgoing.
Below is the log for 'debug vpm signal'
Feb 6 05:33:05.905: htsp_timer_stop3 htsp_setup_req
Feb 6 05:33:05.913: htsp_process_event: [0/3/0, FXOGS_ONHOOK, E_HTSP_SETUP_REQ]fxogs_onhook_setup
Feb 6 05:33:05.913: [0/3/0] set signal state = 0x0 timestamp = 0
Feb 6 05:33:05.913: htsp_timer - 10000 msec
Feb 6 05:33:15.913: htsp_process_event: [0/3/0, FXOGS_WAIT_TIP_GROUND, E_HTSP_EVENT_TIMER]fxogs_offhook_disc
Feb 6 05:33:15.913: htsp_timer_stop
Feb 6 05:33:15.913: [0/3/0] set signal state = 0x4 timestamp = 0
Feb 6 05:33:15.913: htsp_timer - 1000 msec
Feb 6 05:33:15.917: htsp_process_event: [0/3/0, FXOGS_ONHOOK, E_HTSP_RELEASE_REQ]fxogs_onhook_release
Feb 6 05:33:15.917: htsp_timer_stop2
Feb 6 05:33:15.917: htsp_timer_stop3
Feb 6 05:33:16.913: htsp_process_event: [0/3/0, FXOGS_ONHOOK, E_HTSP_EVENT_TIMER]
10-25-2018 04:59 PM
Dears ,
Is there any solution for that issue as i have the same problem with fxo ports with mgcp , incoming calls working fine but i am get busy call with outgoing .
