OVA FILE for CIsco Webex
faithkwamboka
HI All
Im new at the Cisco Webex installation and im trying to get an OVA file as ive seen the iso. isnt going through.
Can someone help me with the procedure for the same.
Thanks you
Faith
Jaime Valencia
Start by reading the documentation:
http://www.cisco.com/c/en/us/td/docs/collaboration/CWMS/2_0/Administration_Guide.html
If that's not your version, look the doc for your version on cisco.com
java
if this helps, please rate
The doc is not helpfull, where is the download for the OVA, only find ISO
Jaime's document link outlines what needs done and is helpful.  The OVA file should be acquired via PUT as I recall.  These are things you should have either already obtained or got information on from your Cisco rep.
