PIMG integration into AVAYA ???
kleo
Level 3
Level 3
I'am a bit confused how come all Intel NetStructure documentation shows using a 2-wire digital 8434 set for integration, and in the cisco documentation it says I must configure for a 7434 (4-wire) or it won't work? I don't have any 4-wire digital circuit packs? what gives ??????
Intel dcomumentation here:
http://resource.intel.com/telecom/support/pimg/manuals/1947-01.pdf
archiestepp
I'm running into the same question for a unity to avaya s8500 integration. Was there ever a resolution to this?
Thanks in advance...
2-wire digital 8434 works.
Just have to stack a whole bunch of PIMG devices if you require many ports :(
archiestepp
