12-10-2011 10:25 AM - edited 03-19-2019 04:05 AM
I am at my wits ends here....
I had a workign configuration 2 days ago, then I upgraded my Ubuntu desktop to 11.10, which updated my postgresql database. Long story-short, I redid my postgresql external database. It is now an Umbuntu desktop 11.10, postgresql 9.1 and I have pgAdmin3 v1.14.
It is showing connected through Cisco presence and the Cisco tc tables do exist. My problem is the tables are not updating. I am verifying this through pgAdmin using the provided Cisco SQL scripts. I have restarted the postgresql service, rebooted the postgre server and restarted the Cisco presence server.
What step am I missing?
Dan
Solved! Go to Solution.
12-12-2011 04:31 AM
Hi Dan,
There are some changes done in postgresql 9.1 and you will need to add the following lines in the postgresql.conf
escape_string_warning = off
standard_conforming_strings = off
Can you give it a try and restart the sql service ?
HTH,
Christos
12-12-2011 04:31 AM
Hi Dan,
HTH,
Christos
12-12-2011 05:55 AM
Perfect!
Thank you very much
Dan
