Greetings,
i'm experiencing some audio quality issues on my PRIs, started recently and nothing changed on our enviroment - below is what is experienced and Telco says they see no errors on their side (they reloaded and still the issue continues):
- Crackling noise on inbound calls (none on internal calls)
- When far end is silence, sounds like they're watching a TV though they report to be alone in the room (more like crossed lines when there is silence on the call).
Reaction:
- First rebooted the GW to no luck
- Added and removed commands below on voice ports, no change:
compand-type u-law
bearer-cap Speech
**When we add on all voice-ports we are unable to make calls
Configs:
aqm-register-fnf
card type e1 0 0
card type e1 0 1
logging buffered 10000000
no logging rate-limit
enable secret 5 sdsdsds
no aaa new-model
clock timezone SAST 2 0
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/1
network-clock-select 2 E1 0/1/1
network-clock-select 3 E1 0/1/0
network-clock-select 4 E1 0/0/0
controller E1 0/0/0
pri-group timeslots 1-31
description 0111114000
controller E1 0/0/1
controller E1 0/1/0
description 0117574000
controller E1 0/1/1
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
voice-port 0/0/0:15
translation-profile incoming ForDNIS
timeouts interdigit 4
bearer-cap Speech
voice-port 0/1/0:15
compand-type u-law
description BACKUP PRI - 0117574000
bearer-cap Speech
voice-port 0/0/1:15
bearer-cap Speech
voice-port 0/1/1:15
compand-type u-law
bearer-cap Speech
