Problem for establishing a call session
I can't establish outgoing and incoming calls with my headquater. I see in the logs cause failure Cause Value=127.
In my side I have ISR4321 voice security router which is CME.  In my headquarter I have one cisco2921 voice security router which is voice gateway and CUCM Cluster. I am connected with my headquarter by an IPsec GRE VPN. The tunnel is up and I can ping each side. You can see below the debug voice ccapi inout
Sep 26 15:38:29.641: //4246/0C589B509650/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=7005
   ----- ccCallInfo IE subfields -----
   cisco-ani=7005
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1304
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFFFFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Sep 26 15:38:29.642: //4246/0C589B509650/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x7F2A5F104978, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=7005,(Calling Name=Brou Ange)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1304(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1000, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Sep 26 15:38:29.642: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep 26 15:38:29.642: :cc_get_feature_vsa malloc success
*Sep 26 15:38:29.642:  cc_get_feature_vsa count is 2
*Sep 26 15:38:29.642: :FEATURE_VSA attributes are: feature_name:0,feature_time:139819981580396,feature_id:727
*Sep 26 15:38:29.642: //4246/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Sep 26 15:38:29.642: cc_api_get_xcode_stream : 4983
*Sep 26 15:38:29.642: //4246/0C589B509650/CCAPI/cc_api_event_indication:
   Event=101, Call Id=4246
   Event Is Sent To Conferenced SPI(s) Directly
*Sep 26 15:38:29.642: //4247/0C589B509650/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Sep 26 15:38:29.642: //4247/0C589B509650/CCAPI/ccCallSetContext:
   Context=0x7F2A688226B0
*Sep 26 15:38:29.642: //4246/0C589B509650/CCAPI/ccSaveDialpeerTag:
*Sep 26 15:38:29.643: //4247/0C589B509650/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Sep 26 15:38:29.643: //4247/0C589B509650/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
*Sep 26 15:38:29.643: //4246/0C589B509650/CCAPI/ccGetMediaClassTag:
   media class tag 0
*Sep 26 15:38:29.643: //4246/0C589B509650/CCAPI/ccSetMediaclassIp2ipTags:
*Sep 26 15:38:29.643: //4247/0C589B509650/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
*Sep 26 15:38:29.643: //4246/0C589B509650/CCAPI/ccGet_xc_nr_asp_info:
*Sep 26 15:38:29.643: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
   Call Id 4246
   media class tag 0
   media class tag 0
   Call Id 4247
   Call Id 4246
   media class tag 0
   media class tag 0
   Call Id 4247
   Call Id 4246
   media class tag 0
   media class tag 0
   Call Id 4247
   Call Id 4246
   media class tag 0
   media class tag 0
*Sep 26 15:38:29.644: //4247/0C589B509650/CCAPI/ccGet_xc_nr_asp_info:
*Sep 26 15:38:29.644: //4246/0C589B509650/CCAPI/ccGet_xc_nr_asp_info:
*Sep 26 15:38:29.644: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active:
   Call Id 4247
   Call Id 4246
*Sep 26 15:38:29.644: //4247/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Sep 26 15:38:29.644: cc_api_get_xcode_stream : 4983
*Sep 26 15:38:29.644: //4247/0C589B509650/CCAPI/cc_api_call_proceeding:
   Interface=0x7F2A5F104978, Progress Indication=NULL(0)
*Sep 26 15:38:29.645: //4247/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Sep 26 15:38:29.645: cc_api_get_xcode_stream : 4983
*Sep 26 15:38:29.843: //4247/0C589B509650/CCAPI/cc_api_call_disconnected:
   Cause Value=127, Interface=0x7F2A5F104978, Call Id=4247
   Call Entry(Responsed=TRUE, Cause Value=127, Retry Count=0)
*Sep 26 15:38:29.844: //4246/0C589B509650/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Sep 26 15:38:29.844: //4247/0C589B509650/CCAPI/ccCallSetAAA_Accounting:
   Accounting=1, Call Id=4247
*Sep 26 15:38:29.844: //4247/0C589B509650/CCAPI/ccCallDisconnect:
   Cause Value=127, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=127)
   Cause Value=127, Call Entry(Responsed=TRUE, Cause Value=127)
*Sep 26 15:38:29.844: //4247/0C589B509650/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x7F2A5F104978, Tag=0x0, Call Id=4247,
   Call Entry(Disconnect Cause=127, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Sep 26 15:38:29.844: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Sep 26 15:38:29.844: :cc_free_feature_vsa freeing 7F2A6055A860
*Sep 26 15:38:29.844:  vsacount in free is 1
*Sep 26 15:38:29.844: //4246/0C589B509650/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=1001, Params=0x7F2A6882C5C8, Progress Indication=NULL(0)
*Sep 26 15:38:29.844: //4246/0C589B509650/CCAPI/ccCheckClipClir:
   In: Calling Number=7005(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=7005(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Destination Pattern=1..., Called Number=1304, Digit Strip=FALSE
   Calling Number=7005(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Redirect Number=, Display Info=Brou Ange
   Account Number=7005, Final Destination Flag=FALSE,
   Guid=0C589B50-C0D9-11E8-9650-B5168BD7C5BB, Outgoing Dial-peer=1001
You can see also the show run of my branch router:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.09.18 14:19:20 =~=~=~=~=~=~=~=~=~=~=~=
Building configuration...
Current configuration : 12541 bytes
! Last configuration change at 18:21:14 UTC Mon Sep 17 2018 by Admin
version 15.5
no platform punt-keepalive disable-kernel-core
hostname CME_ABJ
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$0mPk$7/ND3UuF10y7e.C/.ugMY/
no aaa new-model
ip domain name pikasso.ci
ip dhcp conflict resolution
ip dhcp excluded-address 10.2.2.1 10.2.2.10
ip dhcp excluded-address 192.168.30.1 192.168.30.50
 ip dhcp pool Voice
 network 10.2.2.0 255.255.255.0
 option 150 ip 10.2.2.1
 default-router 10.2.2.1
 dns-server 8.8.8.8
ip dhcp pool Data
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.1
 dns-server 8.8.8.8
subscriber templating
isdn switch-type basic-net3
voice service voip
 ip address trusted list
  ipv4 3.3.3.3 255.255.255.255
  ipv4 1.1.1.1 255.255.255.255
  ipv4 2.2.2.2 255.255.255.255
  ipv4 6.6.6.6 255.255.255.255
  ipv4 0.0.0.0 0.0.0.0
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol none
 h323
  billing b-channel
  h225 display-ie ccm-compatible
  no call service stop
 sip
  bind control source-interface GigabitEthernet0/0/1.10
  bind media source-interface GigabitEthernet0/0/1.10
  registrar server
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729br8
 codec preference 4 g729r8
voice class h323 1
  h225 timeout tcp establish 30
voice register global
 mode cme
 source-address 10.2.2.1 port 5060
 max-dn 150
 max-pool 35
 load 8945 SIP894x.9-4-2SR3-1
 load 7841 sip78xx.12-1-1SR1-4
 authenticate register
 timezone 22
 time-format 24
 date-format D/M/Y
 url directory http://10.2.2.1/localdirectory
 tftp-path flash:
 create profile sync 0005115001946422
 network-locale FR
 user-locale FR
 camera
 video
voice register dn  1
 number 7001
 allow watch
 name Richard Chirara
 label Richard Chirara
voice register dn  2
 number 7002
 allow watch
 name Melodie Manseau
 label Melodie Manseau
voice register dn  3
 number 7003
 allow watch
 name Charbel
 label Charbel
voice register dn  4
 number 7004
 allow watch
 name Raoul Adjiwanou
 label Raoul Adjiwanou
voice register dn  5
 number 7005
 allow watch
 name Brou Ange
 label Brou Ange
voice register dn  6
 number 7006
 allow watch
 name Poste 1
voice register dn  7
 number 7007
 allow watch
 name Poste 2
 label Poste 2
voice register dn  8
 number 2282
 name Ange Brou
 label Ange Brou
voice register dn  9
 number 2280
 name Raoul
 label Raoul
voice register dn  10
 number 2281
 name Melodie
 label Melodie
voice register dn  11
 number 2283
 name Richard
 label Richard
voice register pool  1
 busy-trigger-per-button 2
 id mac C800.84EC.96AD
 type 8945
 number 1 dn 1
 number 2 dn 11
 cor incoming telephone-fixe default
 username test1 password test1
 codec g711ulaw
 camera
 video
voice register pool  2
 id mac C800.84EC.9ABB
 type 8945
 number 1 dn 2
 number 2 dn 10
 username test2 password test2
 codec g711ulaw
 camera
 video
voice register pool  3
 id mac C800.84AA.AD54
 type 7841
 number 1 dn 3
 username test3 password test3
 codec g711ulaw
voice register pool  4
 id mac E0D1.73E4.F415
 type 7841
 number 1 dn 4
 number 2 dn 9
 username test password test4
 codec g711ulaw
voice register pool  5
 id mac E0D1.73E4.F158
 type 7841
 number 1 dn 5
 number 2 dn 8
 username test5 password test5
 codec g711ulaw
voice register pool  6
 id mac E0D1.73E4.F1E6
 type 7841
 number 1 dn 6
 username test6 password test6
 codec g711ulaw
voice register pool  7
 id mac C800.84AA.AE71
 type 7841
 number 1 dn 7
 username test7 password test7
 codec g711ulaw
voice-card 0/2
 no watchdog
license udi pid ISR4321/K9 sn FDO22150UYP
username Admin password 0 Pikasso@1
redundancy
 mode none
vlan internal allocation policy ascending
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 --More--          group 2
crypto isakmp policy 2
 encr 3des
 group 2
crypto isakmp key Cisco@CI_VPN address 212.40.132.22
crypto isakmp key Cisco@CI_VPN address 77.42.156.122
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
 mode tunnel
crypto ipsec transform-set ESP-SHA-AES esp-aes esp-sha-hmac
 mode tunnel
crypto ipsec profile VTI
 set transform-set ESP-3DES-SHA
crypto ipsec profile VTI-CI
 set transform-set ESP-SHA-AES
 --More--         !
crypto dynamic-map SDM_DYNMAP_1 1
 reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
crypto map Voice 10 ipsec-isakmp
 set peer 212.40.132.22
 match address VoiceToLebanon
crypto map Voice 20 ipsec-isakmp
 set peer 77.42.156.122
 --More--         !
interface Loopback0
 ip address 6.6.6.6 255.255.255.255
interface Tunnel9
 description Tunnel-To-Lebanon---->SODETEL
 ip address 10.10.9.2 255.255.255.252
 tunnel source 192.168.40.5
 tunnel mode ipsec ipv4
 tunnel destination 212.40.132.22
 tunnel protection ipsec profile VTI
interface Tunnel99
 description Tunnel-To-Lebanon---->Ogero
 ip address 10.10.99.2 255.255.255.252
 tunnel destination 77.42.156.122
interface GigabitEthernet0/0/0
 ip address 192.168.40.5 255.255.255.0
 ip nat outside
 ip access-group voice-acl-in in
 negotiation auto
 no ip address
 ip nat inside
 negotiation auto
 description voice vlan
 encapsulation dot1Q 10
 ip address 10.2.2.1 255.255.255.0
 ip nat inside
 h323-gateway voip interface
 h323-gateway voip bind srcaddr 10.2.2.1
interface GigabitEthernet0/0/1.20
 description data vlan
 encapsulation dot1Q 20
 ip address 192.168.30.1 255.255.255.0
 ip nat inside
interface Service-Engine0/2/2
 vrf forwarding Mgmt-intf
 no ip address
 shutdown
 negotiation auto
interface BRI0/2/0:0
 no ip address
 isdn transition-delay 1
 isdn point-to-point-setup
 isdn incoming-voice voice
 isdn sending-complete
interface BRI0/2/1:0
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
router eigrp 200
 network 10.2.2.0 0.0.0.255
 network 10.10.9.2 0.0.0.0
 network 10.10.99.2 0.0.0.0
ip nat inside source list 102 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0/0/0
ip route 0.0.0.0 0.0.0.0 192.168.40.1
ip route 77.42.156.122 255.255.255.255 192.168.40.1
ip route 212.40.132.22 255.255.255.255 192.168.40.1
ip ssh version 2
ip access-list standard EIGRP
 permit 131.107.3.189
 permit 131.107.3.66
 permit 192.168.150.0 0.0.0.255
ip access-list extended TELNET-SSH-ACCESS
 permit ip host 192.168.40.5 any
ip access-list extended VoIP
 permit tcp 10.0.0.0 0.0.0.255 any eq 1720
 permit udp 10.0.0.0 0.0.0.255 any range 16384 32767
 permit tcp 20.0.0.0 0.0.0.255 any eq 1720
 permit udp 20.0.0.0 0.0.0.255 any range 16384 32767
 permit tcp 30.0.0.0 0.0.0.255 any eq 1720
 permit udp 30.0.0.0 0.0.0.255 any range 16384 32767
ip access-list extended VoiceToLebanon
 permit ip 10.2.2.0 0.0.0.255 192.168.150.0 0.0.0.255
 permit ip 192.168.30.0 0.0.0.255 131.107.0.0 0.0.255.255
ip access-list extended voice-acl-in
 permit gre any any
 permit tcp any host 192.168.40.5 eq 22
 permit tcp any host 192.168.40.5 eq telnet
 permit tcp any host 6.6.6.6 eq 1720
 permit udp any host 6.6.6.6 range 16383 32767
 permit tcp any host 192.168.40.5 eq 443
 deny   ip 127.0.0.0 0.255.255.255 any
 permit udp any host 192.168.40.5 eq isakmp
 permit udp any host 192.168.40.5 eq non500-isakmp
 permit esp any host 192.168.40.5
 permit ahp any host 192.168.40.5
 permit tcp any host 192.168.40.5 established
 permit ip any any
access-list 102 deny   ip 192.168.30.0 0.0.0.255 131.107.0.0 0.0.255.255
access-list 102 permit ip 192.168.30.0 0.0.0.255 any
tftp-server flash:SIP894x.9-4-2SR3-1.loads
tftp-server flash:SIP894x.9-4-2SR3-1.bin11.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin10.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin9.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin8.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin7.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin6.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin5.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin4.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin3.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin2.sgn
tftp-server flash:SIP894x.9-4-2SR3-1.bin1.sgn
tftp-server flash:sip78xx.12-1-1SR1-4.loads
tftp-server flash:sboot78xx.12-1-1SR1-4.sbn
tftp-server flash:sboot2.78xx.12-1-1SR1-4.sbn
tftp-server flash:rootfs78xx.12-1-1SR1-4.sbn
tftp-server flash:rootfs2.78xx.12-1-1SR1-4.sbn
tftp-server flash:kern78xx.12-1-1SR1-4.sbn
tftp-server flash:kern2.78xx.12-1-1SR1-4.sbn
tftp-server flash:BOOT894x.0-0-2-0.bin.sgn
control-plane
voice-port 0/2/0
 compand-type a-law
voice-port 0/2/1
 compand-type a-law
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
 --More--         !
dial-peer cor custom
 name international
 name telephone-fixe
 name telephone-portable
 name local
dial-peer cor list international
 member international
dial-peer cor list telephone-fixe
 member telephone-fixe
dial-peer cor list telephone-portable
 member telephone-portable
dial-peer cor list local
 member local
dial-peer voice 1 pots
 --More--          corlist outgoing telephone-portable
 description appel-cellulaire-fixe
 destination-pattern ........
 port 0/2/0
 forward-digits 8
dial-peer voice 2 pots
 corlist outgoing telephone-fixe
 description appel-fixe
 destination-pattern 3.......
 port 0/2/0
 forward-digits 8
dial-peer voice 3 pots
 destination-pattern 2.......
 port 0/2/0
 forward-digits 8
dial-peer voice 4 pots
 corlist outgoing international
 description appel-international
 --More--          destination-pattern .T
 port 0/2/0
 forward-digits all
dial-peer voice 5 pots
 incoming called-number .
 direct-inward-dial
 port 0/2/0
dial-peer voice 1000 voip
 description Outgoing-Calls
 preference 1
 max-conn 4
 destination-pattern 1...
 session protocol sipv2
 session target ipv4:192.168.150.2
 voice-class codec 1
 voice-class sip early-offer forced
 dtmf-relay rtp-nte
 no vad
dial-peer voice 2000 voip
 description incoming calls
 --More--          destination-pattern 7...
 session target ipv4:10.2.2.1
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 1001 voip
 preference 2
 max-conn 4
 session target ipv4:192.168.150.1
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 10 pots
gateway
 timer receive-rtp 1200
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password pikasso
 login local
end
I have also configured my branch router as H323 gateway in CUCM cluster. You can see in attached the network architecture.
Best Regards,
ARISTIDE
0 Replies 0
