Problem incoming call on gateway
akram.root
Level 4
Level 4
I have a problem with incoming call on gateway no working , but outgoing call are work fine.
I have a E1 configured , and integration between cucm and gateway in sip .
you can find below the config  and debug of the gateway.
Can you help me please !
Best regards
Jaime Valencia
And what did you find after reviewing the debugs, and then matching what you're receiving from the telco to your configuration?
java
if this helps, please rate
