Removing digits on incoming called number
Mihkel Laur
Hello!
I am asking advice on what would be the best practice in this scenario:
Inner DN numbers are 7 Digits long
For the numbers to be routable inside the network with other PBXs, they need to be 13 digits. The first 6 are for routing and are always the same.
When dialing out, I am using external mask on the routing pattern. So my number appears as xxxxxx xxxxxxx.
What would be the best way for discarding the first 6 digits (so that they can be routed in CUCM) when they are calling back?
CUCM version 11.5
For SBC we have CUBE
Thanks in advance
sudaggar
This can be accomplished by creating called party transformation pattern in CUCM.
create called party transformation pattern:
pattern: xxxxxx.xxxxxxx
put in a partition
called party transformations:
discard digits: predot
and put called party transformation CSS (having above partition) on inbound trunk or gateway.
TONY SMITH
Two ways.  (1) Use a voice translation rule in the CUBE to truncate the number.  (2) Use a translation pattern in CUCM, setting the trunk CSS so that's all that it sees.
sudaggar
put in a partition
Thank you!
We tried with CUBE but had some issues. This solution worked immediately.
All the best
Great. Good to see proposed solution worked.
