Replace MCS7825I5-K9-CMD2
I need to replace my server MCS7825I5-K9-CMD2, but this product has been recalled, which device do you recommend for replacement with the same features?.
Jaime Valencia
All MCSs have been sold out, if your CUCM version is supported on UCS, thats the way to go.
java
if this helps, please rate
