02-07-2022 08:56 AM
I have a NIM-2MFT-T1/E1 that needs replacing in a 4331/K9, I am assuming I can use a NIM-4MFT-T1/E1 that I have available as a replacement? Also is there anything else I need to do for the router to recognize the different module?
Peter
Solved! Go to Solution.
02-07-2022 09:03 AM
You can use NIM-4MFT-T1/E1. Make sure you put the PVDM on nim module. Since it’s a 4 port, recommends will be 128 pvdm if you are using all 4 ports.
02-07-2022 09:03 AM
02-07-2022 09:07 AM
