Request of Unified Communication Solution READ MATERIAL
Edson Vuma
Hi, everyone.
I am actually preparing a cientific document at my university and I have a lot of things to read.
So, I have chosen to right  about Cisco Unified Communication Solution.
I will organize my document in chapters, but at first, I need this base, all material about Unified Communication, how did this concept started and why.
Which are the benefits of it and all this info.....etc
The second step, is to choose the best products of this UNIFIED COMMUNICATION Solution, how to choose, according to a specific case-study needs.
Please, send as many books/links as you find.
If are from different autors, would be better.
Can you help me on this??
Is very important for me.
Best regard and best wishes
Edson Vuma
-- Regards Edson Vuma
keglass
Level 7
Level 7
Edson,
Thank you for posting to the Collaboration Community. I found some resources to get you started on your research. For additional information, I recommend you try a Google search or something similar, as well as further exploration of the cisco.com website.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/index.html
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_case_studies_list.html
I hope that helps.
Kelli Glass
Moderator for the Cisco Collaboration Community
Hi, Kelli
Thanks for your reply.
Anything else, just put it here.
Best regards,
Edson Vuma
