Router and Call manger for small deployment
AAbdelmaksoud
I have 15 employees in a small branch, and I was planning to use a C8200 with DNA-A as a router and call manager for 15x 7821 IP phones.
I was wondering what the exact requirements are (mandatory and optional) for internal and external use.
If I need to use Jabber (internally and externally), what do I need? (SIP trunks and CUBE licenses, etc.)
I was also planning to buy a router with a switch. For the router, what modules should I purchase?
For Flex licenses, what do I need exactly?
Jaime Valencia
You need to reach out to a local partner with UC specializations to discuss what would be the best fit for your needs and your usage requirements. They'll ask you a lot of questions to determine what you need and what's the best fit from the portfolio.
CUCM for just 15 phones seems like overkill.
java
if this helps, please rate
In addition to what @Jaime Valencia mentioned, for this number of users, I would recommend considering cloud UC services such as Webex. Cloud UC solutions offer several advantages, including scalability, cost savings, and ease of deployment.
