RTP Delay and Cuts on
Austin3:16
I have observed an issue with delay and RTP stream interruption during a third incoming call from PSTN, whether directed to UCCX or an IP phone.
here is the log and the capture.
6 Replies 6
Hi Austin,
There's no file attached. can you please check
Carlo
Please rate all helpful posts "The more you help the more you learn"
yes sorry attached the file
What is your deployment?
From your traffic capture I see some disconnection between CUCM  and VG.
Do you have MTP flagged on SIP Trunk between CUCM and VG?
Please let me know
Carlo
Yes MTP is activated
Hi Austin,
Is it always th third call or is a random issue?
Please post your current running config of your VG.
Carlo
Yes with 3 sim calls, the problem solved by the ISP ##- Please type your
reply above this line -##
