Running CUCM 7.x production in Vmware environment
susanto.liu
One of our client still running callmanager version 7.0. Because limited budget. They want order UCS only.
install CUCM 7.0 in Vmware environment and change the MAC address (copy from Publisher) then input license files.
for now,is it possible ?
You CANNOT, that's the thing, even for the jump upgrade, the procedure is meant to be only a middle step and NEVER run that for production.
Cisco will NOT provide licensing for a not supported environment.
java
if this helps, please rate
Jaime Valencia
Possible, but not supported at all by Cisco, and we will not assist on moving the licenses to a an unsupported deployment, or with anything else.
They will be on their own, or their partner will have to assist in ANY problem they have.
We only support 6.x and 7.x on ESXi when you're doing the jump upgrade procedure, NEVER for production.
java
Hi Jaime,
Thank You for your reply.
Would you guide me, how activated the license in Vmware environment , please ?
our client order UCS for Hot Spare / backup unit, if MCS publisher is down within 1 year.
java
Thank you very much Jaime :)
