Secure SIP Trunk to VGW
Gidonitzhak
I'm trying to configure secure sip trunk between CUCM and Voice Gateway, but it fails to set up.
The CUCM and the Voice Gateway are both signed under the same Certificate Authority.
There is a root CA, and a intermediate CA
i did the configurations based on that document:
https://community.cisco.com/t5/collaboration-voice-and-video/configure-sip-tls-using-ca-signed-certificates-between-call/ta-p/3164144
i run the following debug commands and received the following error:
debug crypto pki transaction
debug crypto pki messages
Jan 31 12:35:11.726: CRYPTO_PKI: Unable to locate cert record by issuername
Jan 31 12:35:11.726: CRYPTO_PKI: No trust point for cert issuer, looking up cert chain
if you will see on the logs attached, i configure a trust-point to the root and authenticate the intermediate
IP address of the CUCMs: 100.75.0.10 (publisher), 100.75.0.210, 100.75.0.211, 100.75.0.212 (subscribers)
IP address of the Voice Gateway: 100.75.252.94
i attached a file containing the running config, and the logs from the debugs, and a capture from the CUCM.
Can you help me figure why I'm reeving this error?
0 Replies 0
