Server Name problem on upgrade
tonygray1
Hi Guys
Just another question regarding the problem i am having upgrading from 4.03 to 5.01 and i cant because setup is saying that the server name has changed .
As i installed this machine i no it hasnt been changed.
have checked CSCsj92828 everything is ok
Netbios is wa-vm2
@@servername is wa-vm2
Unity default location home server name is wa-vm2
but as the log shows it fails so what is the code really looking at ? does anyone no ?
IsServerRenamedBefore Test Started. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1096)
2008-07-04T11:59:37 - ...Server Rename Test: - weeklybackupjobs check - PASSED.. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1163)
2008-07-04T11:59:37 - ...Default location=Default741e319f - HomeServer=WA-VM2 (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1236)
2008-07-04T11:59:37 - ...Server Rename Test: Unity default location home server name not match with local machine NetBios name.. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1241)
2008-07-04T11:59:37 - ...DataStore server name=WA-VM2 (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1268)
2008-07-04T11:59:37 - ...Server Rename Test: DataStore server has been renamed.. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1273)
2008-07-04T11:59:37 - IsServerRenamedBefore Test Ended. (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\READINFO.CPP 1098)
2008-07-04T11:59:41 - Mode:Install, Step:FailedStep [IDD_FAILED] (H:\views\CUESB1_view\un_Setup\UnitySetup\InstallExe\Src\MYSETUP.CPP 252)
Rob Huffman
Hi Tony,
Have a look at this tread with a nice fix from John;
"Yes, I ran into this last weekend on an upgrade. There is a missing row that needs to be added.
Here's the BUG ID - CSCsd92113
and the workaround:
Open SQL Enterprise Manager > Databases > UnityDB > UnitySetupParameter.
Right click and return all rows.
Go to the bottom of table.
Under Name column enter: @PrimaryServer
Under Value column enter: Name of Unity server."
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbea35c
Hope this helps!
Rob
No no good i had already looked at that one .
Its seems to be at this point
But the netbios name is wa-vm2 and in AD the home server name is wa-vm2
TG
As Rob said before, go into the unitydabase and look for the table "UnitySetupParameters" and see if you have the following:
If not, just add them manually, that should fix the problem
If this helps pls rate
