Setting a Subsriber on a schedule
Hi All,
we have a department with shared voicemail and wish to close that departments voicemail down at 4pm as no-one will be able to return the calls until next morning, therefore I have created a closed message, created a new schedule with the ammended times and saved the particular subscriber to the newly created schedule. However when making a call to the subscriber it plays the open message.
Any ideas?
Darren.
yes you need to make sure that the alternate greeting is not enabled, if it is it overrides the standard and closed.
Hope this helps.
Randy
6 Replies 6
Jaime Valencia
did you enabled the closed greeting???
javalenc
if this helps, please rate
java
thanks for your speedy reply, yes I did enable the closed greeting, is there no other other settings?
Darren.
Darren.
Hope this helps.
Randy
thanks for that, the alternate message was enabled and once disabled the closed message was activated.
Darren.
Hey I have not been on for a few days but no problem and glad to help.
Thanks too.
Randy
