Setting device owner userID for extension mobility users
itaycohen
Is it possible that the owner userID field will be automatically filled in a device settings according to the userID logged into the device using extension mobility ?
thank you,
Itay
keglass
Level 7
Level 7
Itay,
Check out this Cisco document about extension mobility. I also recommend you post this to the Cisco Support Community for additional feedback and information.
Cisco Unified Communications Manager Features and Services Guide, Release 8.6(1) - Cisco Extension Mobility [Cisco Unifi…
Hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
